Accessory Export Samsung Galaxy S i9000 Silicone Skin Case Cover Logo
Felicity Rasheed Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get my galaxy s charging port fixed and how would the port become loose?
My Samsung galaxy s i9000 is not holding charge i bought a new Samsung battery now i realized the charging port is loose. how can i fix this?
NoName Jack
Level 3:
  • Accessory Ex... Master 1,150 Answers
  • Posted on Jun 29, 2014
NoName Jack
Level 3:
Answers
1150
Questions
Helped
232702
Points
4657
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
1helpful
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 • Cell Phones
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Samsung galaxy s not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
I can not use my i9000 when charging
First Option:
Second Option:
1helpful
Where do you enter the unlock code in the samsung phone
You can Enter the Unlock code in Samsung Galaxy S I9000 using the Unlocking instructions below: You can get the Unlocking instructions at here Wickedunlock.com/samsung-i9000-galaxy-s/rs11wp9/ at free of cost.
Samsung I9000 Galaxy S Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung I9000 Galaxy S mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung I9000 Galaxy S mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung I9000 Galaxy S with a NOT ACCEPTED SIM Card.
2 - Samsung I9000 Galaxy S will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung I9000 Galaxy S shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung I9000 Galaxy S.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung I9000 Galaxy S is locked to.
CODE: Its the unique Unlock Code for your Samsung I9000 Galaxy S.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung I9000 Galaxy S.
Hi can i get a free unlock code for my galaxy s
Free Unlock code can be get for the OLD SAMSUNG,DCT Nokia Phones,But this is Latest PDA Phones,You need to pay for this Model,Get the paid Unlock code from here Onlinegsmunlock and Unlock it safe and secure using the Instructions Below..
Samsung I9000 Galaxy S Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung I9000 Galaxy S mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung I9000 Galaxy S mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
Method 2:
2helpful
I bought my Samsung Galaxy Tab P1010 a month ago and now it wont charge nor the USB be read when i tried to connect it to my laptop. Moreover, the USB cable become so hot in just few seconds after i tried...
It sounds to me like you have an issue with your Galaxy Tab's charging port.
Fortunately it is still under warranty if you've just recently purchased it.
Take it back to the store or contact Samsung for a warranty replacement. They may be able to help you recover items from the memory.
Hope this helped!
Thanks!
Top Accessory Export Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Accessory Export Cell Phone Expert? Answer questions, earn points and help others
