Question about Lenovo Computers & Internet
Laptop Lenovo u260 shows flickering vertical lines.
Hi, my lenovo u260 shows vertical lines over more than half of my screen. Pressing on the keyboard frame occasionally helps, but not always. 1 month guarantee left. What can I do to resolve the problem? Doe I have to change the screen??
SOURCE:
  • 41 Answers
SOURCE: Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Posted on Jul 06, 2008
antiochpc
  • 1314 Answers
SOURCE: vertical line on screen Lenovo T61 Laptop
You have a dead column of pixels. The only solution I'm afraid is to replace the LCD screen.
I'm sorry the news isn't good but can you take a moment and rate the solution as fixya even if it wasn't what you wanted to hear? Thanks! :c)
Posted on Jan 19, 2009
  • 1481 Answers
SOURCE: Hi, thanks a lot for your support. I have been
need to change the LCD screen or the backlite or the invertor board behind the screen
check with a tech shop...
Posted on Apr 27, 2010
Sunnyrepairs
  • 808 Answers
SOURCE: Lenovo Thinkpad SL400 - Screen
Its may b the problem of ur vga use reginout regcleaner to fix ur problems
Posted on Aug 11, 2010
  • 2567 Answers
SOURCE: my lenovo t400 has screen flickering when ever i
Sounds like a problem with the video adapter chip. The chip might be either defective or experiencing bad connection with the motherboard. In order to fix this problem, you will need to disassemble the notebook, pull out the motherboard & inspect the video chip & its connection points to the motherboard. If the video chip is defective, you might have to replace the motherboard.
Posted on Apr 10, 2011
Lining screen
Vertical and Horizontal lines on laptop screen are indications of bad LCD's. Getting it replaced is the ONLY solution for this problem, Sorry.
Oct 18, 2013 | Lenovo Computers & Internet
Lenovo screen lines
Its a sign of bad RAM. Something it happen because of dust in the ram or something its indicate that ram is going to expire. If it is possible so I will recommend you to open your computer and clean the ram and try it again. If the problem will still present then you have to change your RAM.
Oct 17, 2013 | Computers & Internet
Lenovo u260 screen black
Switch back to internal monitor in bios setup or do both internal and external monitor.
Feb 11, 2012 | Lenovo IdeaPad U260 Laptop Computer -...
Got free lenovo ideapad U260 notebook from Starhub. Collected the notebook on last friday and swift on the notebook today for warranty registration. But the screen come out with a lot of line and the...
> shall I continue to register for warranty?
Yes.
> Shall I send down for repair?
Yes, after you contact Lenovo, and get an 'RMA' ("Return Materials Authorization")
authorizing you to ship the computer to them, with the RMA-number as the tracking-number.
> Or Lenovo will change another notebook for me?
It's their choice, namely to REPAIR or REPLACE, under the terms of their warranty.
Jun 06, 2011 | Lenovo IdeaPad Y510 Notebook
I had problem with my webcamera , it did not work properly. can you show me the drive for that. my LENOVO 7757
Hi. You can download the drivers for this machine at consumersupport@lenovo.com, just enter the serial no. and it will give you the drivers for your machine, also try pressing the Fn+Esc Button on your keyboard to enable or disable your webcam. Hope this helps
Jun 08, 2010 | Lenovo 3000 Y410 Laptop
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
Jun 13, 2009 | Lenovo M500 DLP Projector
Visual problem with laptop screen
Can you connect your laptop into another computer screen? See if that works. If so, then your screen is going bad. I would not recommend replacing the screen unless you are a harware expert. If the lines are still there try booting into VGA mode by pressing F8 at first startup. You might have a failing video card or corrupt drivers.
Apr 13, 2009 | Lenovo ThinkPadĀ® Z61m PC Notebook
Computers & Internet Logo
71 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
