Bowl lift will not work
Visit lanas-kenwood-spares.co.uk where you can purchase what you require to fix the problem
You will need the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
The part is most likely the Nylon arm lift part #416287 or 241764
Some suppliers are:
http://www.goodmans.net/d/933/kitchenaid-stand-mixer-repair-parts.htm
http://www.shipfreenow.com/
http://www.seneca-river-trading.com/kitchenaid-stand-mixer-repair-parts.html
http://www.mendingshed.com/kamisc.htm
SOURCE: Kitchenaid pro stand mixer will not turn on
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Testimonial: "Thank you for your post. I will check out the suggestionsl"
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
SOURCE: I need the manual for my K5SS mixer my
Hi WWW_SOCRAFTI, you can easily download both the Owner’s Manual and Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50PPWH0.pdf (5156.65 KB) from the Owners Manuals (9) list and this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
The reason I suggest downloading the Parts List manual is that should you decide to try and troubleshoot and fix your KA mixer, this manual will be invaluable in the disassembly and reassembly of your mixer along with listing all the part names and numbers. Having the correct part names and numbers is critical when reordering replacement parts when your mixer eventually will stop working.
Good Luck with your mixer, I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
SOURCE: Bowl Lift
I had this problem and fixed it with some grease on the bowl lift lever. I used coconut oil for the grease as its obviously food grade. I greased the exterior which was the cause of the problem and the inside of the bowl lift lever. To get to the inside you can flip the mixer over (unplug it first) and remove the base with 3 screws to improve access. If further disassembly is reqired the C clip can be removed from the bottom of the mechanism and then slide the spring out. The bowl lift stand then comes out (you need to remove one screw if it catches) and you can easily reach inside. When putting it back together get someone with small hands. The C clip is easy to drop in the machine and easily lost.
