Dell A940 All-In-One InkJet Printer Logo
A
Anonymous Posted on May 02, 2014
How do l clean the underside of the glass on dell a940 printer
How to clean underside of the glass
5 Related Answers
A
Anonymous
  • Posted on Mar 07, 2008
SOURCE: dell a940 printer
Had the same problem. You should just buy another printer... they are so cheap these days...
Best,
David I. Bleckner
Anonymous
  • 1179 Answers
  • Posted on Apr 08, 2009
SOURCE: lost my installation cd for A940 all in one printer
Go toy www.dell.com, click on the support link. Lookup your specific pronter model #. A list of all available software/drivers will appear. Download and install the ones pertaining to the operating system you are running. You should be all set. Hope this helps.
Anonymous
  • Posted on May 30, 2009
SOURCE: dell a940 printer error 50 c tried without
I had this same problem. I solved it by cleaning the bay where the cartridges go with some 100% Isopropyl Alcohol. Then i just replaced the cartridges with new ones and it worked fine!
Anonymous
  • 1197 Answers
  • Posted on Jul 08, 2009
SOURCE: dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Anonymous
  • 8 Answers
  • Posted on Apr 01, 2010
SOURCE: Dell 1600n printer, how can I clean the platen glass?
you will need to take your printer plastics off to clean.4 screws on back panel take out then one screw on left side cover.take out paper tray open toner door 4 screws to remove,turn on side and on bottom there are 3 tabs both sides to remove side panels.one side has a speaker wire to unplug.take off display cover 3 screws to take out.lift off top cover and remove 4 screws 2 each side lift off platen and clean. reverse the order to put back together.take your time and be careful good luck
If it can get dirty then the seals are broken. Get a new printer.
Terry
How can i add A940 Dell all in one printer to my laptop
jojo,
Click the link below for information and steps installing your Dell A940 Printer on your computer.
http://dell.to/1y1FfWw
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Print problems with A940 dell printer
The print-head pulls ink from the ink-cartridge, and sprays it onto the paper, unless the print-head has become "clogged".
Run a "print-head-cleaning" cycle, to try to unclog it.
Dell A940 won't print
you must be change cartridge cartridge nozel is dry
Dell a940 printer error 50 c tried without
1helpful
2answers
Dell A940
Go to www.support.dell.com
1helpful
Printer Dell A940
this is a common problem
run the clean cartridge utility at least 5 times in a row, and view the test page after every cleaning, there should be an improvement, sometimes it takes more than 5 tries
this should un-clog the nozzles.
if it still not fixed replace the cartridges
thanks for rating
1helpful
Black boxes appearing
Have you tried to clean your print heads?
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
