Question about Linksys Wireless-G WRT54G Router
Scientific atlanta modem not reading linksys wireless router
2 Suggested Answers
SOURCE:
puertobori
  • 7733 Answers
SOURCE: i want to connect a Scientific-Atlanta WebSTAR
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 20, 2010
Scientific atlanta modem is not showing that it is connected to my linksys wireless router
Seems to be that you have cable modem from Scientific atlanta.
  1. Turn off the modem and the router.
  2. Connect the modem to router with ethernet cable on internet port
  3. and computer to router's port no 1.
  4. power up your modem and wait for 2 minutes
  5. then power up your router and wait for 2 minutes and try to go online on computer.
  6. If not , then reset your linksys router by pressing your reset button at the back of the router with help of a pen for 10 sec.
  7. then follow the steps again 1 to 5
  8. try to go online.
  9. if still not , the open up a browser on computer
  10. type 192.168.1.1 in the address bar and hit enter on the key board
  11. leave the user name blank and type admin in the password box
  12. click on subtab of mac address clone under set up tab
  13. click on enable and click on clone my pc's mac tab.
  14. then click on save settings.
  15. and follow the step 1 to 5.
May 02, 2014 | Linksys Wireless-G WRT54G Router
I have a Belkin N150 witreless router. I have a Scientific Atlanta cable modem with a good interenet connection. I can't get the wireless network to work.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 03, 2011 | Computers & Internet
I have a Belkin Wireless G Plus Router connected via Ethernet cable to a Scientific Atlanta cable modem supplied by Virgin. I can't currently get any signal from the Belkin to my MacBook Pro (I've got it...
Make sure the IP of the Router and the IP of the MAC is in the same scope.
E.G. Router: 192.168.1.1 Subnet 255.255.255.0
Mac: 192.168.1.5 subnet 255.255.255.0
Typically the router acts as DHCP-server and distributing ip-adresses automatically, when a computer is connected. But the the IP can also be set manually.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
I can not detect wireless network when I connected the router to Scientific Atlanta modem
(1)upgrade your wireless phone to 5.8GHz
(2) use a corded phone
(3) use awired internet connection to your router.
Jan 08, 2010 | Linksys Wireless-G WRT54G Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
