Computers & Internet Logo
A
Anonymous Posted on May 01, 2014
How to reset gem equinox? - Sony Ericsson Computers & Internet
1995 Ford Windstar. the Dash, wipers, windows, went out, replaced GEM module and still won't work. How do I fix it?
If replacing the GEM module did not fix the issue, the next step is to check the wiring and connections to the GEM module. Make sure all of the wires are properly connected, and check for any signs of corrosion or damage. You may also want to try resetting the GEM module by disconnecting the battery for a few minutes and then reconnecting it. If none of these steps work, then the problem may lie in the fuse box or wiring harness, and you may need to take the vehicle to a qualified technician to have it checked.
1helpful
2answers
Is there a way to reset the GEM
You would need a good scan tool to reset the GEM , Fords are notorious for gem module issues .You can see all data and clear codes but most of the issues are related to water getting into fuse panel under dash between the gem and fuse panel terminals . Common issues would be wipers not turning off or coming on without turning the switch , also the chime sometimes shorts and you hear it beeping while driving . What are your issues ?
1helpful
2014 codes for animal jam
Below is the most recently updated list of codes available on animal jam in 2014!
kama - 500 gems
thanks - imprisoned phantoms
adventure - 500 gems
ngexplorer -1000 gems
friendship - 500 gems
tigris - 500 gems (thanks fish301!)
ganges - 500 gems (thanks ARCTICKWOLFGIRL!)
zambezi - 500 gems (thanks ARCTICKWOLFGIRL!)
chimbu - 500 gems (thanks Nikola!)
nile - 500 gems (thanks Lucas!)
drawing - 500 gems
Alphas - 500 gems
bemybuddy - 500 gems
shadows - 500 gems (thanks Abby!)
explorer - 100 gems
ajbday3 - Animal Jam 3rd birthday cake
10million - 10 million banner
Animal jam all codes
Codes
Here Are All The Working Known Animal Jam Codes! Each Code Will Reward Your Animal Jam Jems Or An Iteam! Just Enter The Code In The Box Titled Code When You Log In!
Here is a list of gem codes that are still valid, starting from the oldest.
All these are proven to work.
  • explore2012 -- 1,000 gems
  • explorer -- 100 gems
Possible gems you can earn right now: 1,100
Here is a list of inventory codes that are still valid, starting from the oldest.
  • gecko -- lime green gecko plushie (Note: This code is currently having major glitches. You cannot receive the item, even if you press 'Accept'. Animal Jam has been notified of this.)
Here is a list of gem codes that have expired, starting from the oldest.
All these have been proven not to work.
  • playwild -- 1,000 gems
  • playfree -- 1,000 gems
  • NewYearJam -- 1,000 gems
  • potion --1,000 gems
  • danceparty -- 1,000 gems
  • foodfight -- 1,000 gems
  • discovery -- 1,000 gems
  • campwild -- 1,000 gems
  • moviebytes -- 1,000 gems
  • playsmart -- 1,000 gems
  • festival -- 1,000 gems
  • hammock -- 1,000 gems
  • speedy -- 1,000 gems
  • gorilla -- 1,000 gems
  • celebrate -- 1,000 gems
  • treasure -- 1,000 gems
  • coralreef -- 1,000 gems
  • croc -- 1,000 gems
  • spooky -- 1,000 gems
  • deepsea -- 500 gems
  • treat -- 100 gems
  • phantoms -- 500 gems
  • feast -- 1,000 gems
  • roar -- 1,000 gems
  • Jamaalidays -- 500 gems
  • BFF4EVER -- 100 gems
Possible gems you could have earned: 22,700
Here is a list of inventory codes that have expired, starting from the oldest.
  • AJBDAY - Animal Jam 1st Birthday Cake
These are all the codes as of March 31, 2012.
National Geographic publishes a magazine every other month containing 1-5 codes. If you'd like to be more up-to-date, we suggest you subscribe to it.
Note: These codes are subject to change and may not always be valid.
Other note: Codes are not case-sensitive.
I don't play it myself but here you go.
explorer - 100 gems
ngkidsrox - 1000 gems
discovery - 1000 gems
AJBDAY3 - 3rd Birthday Cake
AJHQ3000 - 500 gems
10million - 10 Million Banner
ngexplorer - 1000 gems
drawing - 500 gems
hooot - 500 gems
alphas - 500 gems
kangaroo - 500 gems
koala - 500 gems
dolphin - 500 gems
shadows - 500 gems
1helpful
Keyless entry not working. 2010 equinox
reset itself. may have been something obstructing rear gate from closing all the way.
11helpful
3answers
How do i reset my oil light? my husband changed
TURN THE IGNITION KEY TO RUN WITH THE ENGINE OFF.FULLY PRESS AND RELEASE THE ACCELERATOR PEDAL THREE TIMES WITH IN FIVE SECONDS.YOU HAVE TO DO THIS MORE THAN ONE TIME.ITS NOT GOING TO RESET FIRST TRY BUT DO THIS PROCEDURE.UNTIL THE CHANGE ENGINE OIL LIGHT WILL FLASH WHILE THE SYSTEM IS RESETTING.TURN THE KEY TO OFF.WAIT A FEW SECONDS.START CAR UP TO SEE IF CHANGE OIL LIGHT COME BACK ON.IF YES YOU HAVE TO TRY THE RESET PROCEDURE AGAIN.
8helpful
3answers
How do I reset the change oil soon light?
Hi to reset the oil life monitor
turn the key on engine off
push the gas pedal to the floor 3 TIMES WITH IN 5 SECONDS
the light will flash then go out
Top Sony Ericsson Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
August Brown
August Brown
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
