Nady Systems DKW Duo Microphone Logo
A
Anonymous Posted on May 01, 2014
Nady dkw duo latency - Nady Systems DKW Duo Microphone
Dkw crankshaft
In fact I\'m adding my problem. I\'m trying to develop a jig in order to mount dkw crankshafts. So, I\'m looking for some technical information to subside my job. Here, in Brazil, despite the fact that these cars had been produced for almost 11 years, from 1956 until 1967, we don\'t have information and people involved in this process to tell us how they did that. We have a lot of crankshafts to be repaired and the way we\'ve been doing is disastrous. So, any technical information or information from people who had worked with this in the DKW factory will be very well come. Thank you.
How to connect a microphone to a Nady SRA 2150?
Contact Nady. They should be able to tell you how to connect the mic to their system.
Where can i find a power supply/cord for this product
Looking myself...let me know if you find one
Latency Problms
You'll never get rid of the latency problem if you record from a speaker. Speakers are analog and when you mix digital with analog you get latency.
Broke the antenna off my Encore II . Where can I get parts?
Contact Nady directly at the number below. They will help with the part number and cost etc.
Dan
Contact: Customer Service Department at (510) 652-2411.
I have a mxl 990 microphone and its hooked up to a Pro tools LE 8 Mbox Mini . when im recording on protools or any other software with this mic, i hear a static/popping sound and it records the popping...
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise. Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away. somervta_0.jpgThis is what the dialogue might look like. another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
Nady Ht-duo cordless microphone, new 9 volt battery. Red battery light should stay on, but comes on then goes out. Checked contacts, no problem there.\r\n Thanks,
Nope.
The red light should blink when turned on and then go out. That is normal. When the red light stays on, the battery needs to be changed.
Dan
Neeed my NADY 151 VR repaired. Can somebody do
Take it to a music store that sells and services Nady products.
Top Nady Systems Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Nady Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
