SOURCE: Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
SOURCE: Toner Exhausted
RESET YOUR PRINTER
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
[email protected]
SOURCE: need to download free samsung ml 1640 printer
Here is the support page for your printer:
Samsung ML-1640 Support
You can download drivers, manuals and firmware and there are other links to help you.
Thanks for using Fixya.
SOURCE: how can i do 0 for ml-1640 page count ,and want to resetpagecount
You have to flash the printer with the fixed firmware and it will never ask you again for a new toner cartridge :) it is a 1 minute job for me and i charge my Local customers 10 Euro mostly because it has to be done just once and then you just refill the cartridge without doing anything else ( this is just an explanation - i don't want your money)
SOURCE: The upper red light is
Look to see if there is a job sitting in the queue and delete it, then for good graces, unplug the machine and let sit for 20 minutes, it will assist in clearing the memory chip too, the plug in and it should be back to normal! please let me know if this does not tackle it, we can go from there. Take Care!! Guy :)
Testimonial: "Guy you're my main man! It worked and i'll be able to print my paper and stay out of trouble, i'm very greatfull, thanks a lot!"
