Off and on silvaniatv lc195sl8
Http://www.searspartsdirect.com/partsdirect/user-manuals/lc195sl8-sylvania-parts-tv+lcd-manual [] Control Panel
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
SOURCE: need a convertor box
Hello, I see that you might be confused about the new digital T.V. signal. Well I hope this information will help ease things. After reviewing your information your T.V. will accept both signals, if you are using an antenna for getting channels then your are good to go, but its best if use an outdoor antenna if you live outside local city areas. If you run the channel scan you should recieve both signals with this model. After Feb. 19, 2009 you should run the channel scan again to be sure it's programmed all the stations in. I hope this will help. Again a regular outdoor antenna connected to the T.V. will do just fine. I hope this has helped you. We look forward to helping out in the future, Thanks.
