Maytag Bravos MTW6600T Top Load Washer Logo
P
Peter Giang Posted on May 01, 2014
What is hd code???? - Maytag Bravos MTW6600T Top Load Washer
Dawn Allynn
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on May 01, 2014
Dawn Allynn
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
3070
Points
33
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
I need a code for a bush bpdp 42 hd 2 tv for my sky hd box
2577 worked for me for the Bpdp 42 hd bush tv
4answers
Unlock code for htc desire hd imei no.356299042412070
I need you to know before you decide to use free HTC Desire HD unlock code in your phone. Free unlock code is not reliable and usually make your phone hardlocked so you need to fix it at mobile repair shop. I sugest you to purchase reliable htc unlock code for small price at third parties sites rather than use unknown code.
I need codes for universal remote for access hd tv
Can I use a universal remote and if so which one and what is the code for access hd dta1030 converter
4answers
I want to unlock htc touch hd
You can Unlock it simple by using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-1.pngTheunlockarena and Unlock it...You can follow the instructions below and Enter the code
HTC Touch HD Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Touch HD mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Touch HD mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Touch HD with a Not ACCEPTED SIM Card.
2. If your HTC Touch HD asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch HD will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch HD is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Touch HD is locked to.
2helpful
2answers
Htc touch hd sim unlock codes
thats not availabel for free yet, but you can find some for a good price on the web. good luck
Toshiba hd ep 30kb
All HD discs are region free but the standard dvds are mostly region coded.
Toshiba hd dvd remote codes
you can get the users manual online on toshiba's website.
Toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
Toshiba hd dvd A20 remote codes
i am having the same problem with the HD-A2KU hd dvd player not recognizing any of the codes. it seems that the dvd player does recognize the codes but will not control the player. when i click the on off button the dvd player changes to a word but does not turn it off or control it.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
