Motorola Radius Vhf Sp21 2 Way Radio Walkie Talkie With Charger P23rrb23f2aa Logo
A
Anonymous Posted on May 01, 2014
Which is better, vhf or uhf - Motorola Radius Vhf Sp21 2 Way Radio Walkie Talkie With Charger P23rrb23f2aa
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Oct 01, 2014
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796364
Points
4248
In many business settings you can use either VHF or UHF with success.
VHF: Especially good for people who work somewhat line-of-sight or outdoors. VHF gets around rocks, dirt, hills and trees well and can also be used in many indoor situations.
UHF: While VHF and UHF will both operate line-of-sight up to 2 miles, UHF (450mAH range) gets in and around metal better and even has a better metal punching capability. It also works well in and around concrete structures.
5 Related Answers
eradiostore
eradiostore
  • 1672 Answers
  • Posted on May 06, 2009
SOURCE: Is it uhf or vhf?
Model H01SDC9AA2AN:
HT1000 UHF 450-520 MHz, 8 Channel, 4 watt, Portable Radio
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jun 07, 2009
SOURCE: Need to know if MTS2000 MODEL H01UCD6PW1BN is VHF
No, it is 800 MHz
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jul 28, 2009
SOURCE: Is it UHF or VHF
This is a UHF radio.
SDC is 450-520 MHz.
RDC is 403-470 MHz.
As you can see the two bandsplits overlap in the common 450-470 MHz range. If your frequency is between these numbers either of the HT1000 models will work for you.
FYI: VHF has the letters KDC usually.
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Jan 11, 2010
SOURCE: is the motorola MU21CV a UHF or VHF??????
MU21CV is a UHF radio.
MU= UHF
MV = VHF
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/Spirit_M_Series_E.pdf
You can find a frequency chart on page 10.
Best regards.
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Feb 22, 2011
SOURCE: I have a set of Motorola P110 radio's (4 of them)
Yes, you are UHF.
Best regards.
I kenwood TK-2000 radios. when I read the radio, all the frequencies listed are vhf frequencies.but when I program a vhf frequency it says it is out of band it can only accept 400 to 440 mhz.This goes for...
Based on the information you provided, it seems like the Kenwood TK-2000 radios you have may have been programmed with the wrong band split. The TK-2000 is available in both VHF and UHF frequency ranges, and it's possible that the radios you have are actually UHF models, despite being listed as VHF frequencies when you read the radios.
To check if your radios are UHF or VHF, look for a label on the back of the radio that specifies the frequency range. If it says UHF, then the radios can only accept frequencies in the 400-440 MHz range. If it says VHF, then the radios should be able to accept frequencies in the VHF frequency range.
If you've confirmed that the radios are indeed VHF models, then it's possible that the band split settings may need to be adjusted in the programming software to match the specific VHF frequencies you're trying to program. I recommend checking the manual for your programming software to ensure that you have selected the correct band split settings before programming the radios. If you're still having issues, it may be helpful to contact Kenwood customer support for further assistance.
Are vhf and uhf compatible cp200
uhf is not compatible with vhf
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Why is the VHF/UHF function needed. Seems to be working no matter which position it is in.
They are simply different MHz of frequency wave. You should choose according to your environment. VHF works best out-of-doors or line-of-sight, especially around rocks, hills, dirt and trees. UHF has a better ability to work in and around buildings, metal, concrete, and brick. Either will work short distances radio-to-radio and line-of-sight. You will just get better range when using VHF or UHF in the environments described.
Best regards.
How can i tell if i have a uhf or vhf motorola cp200
The model number for a VHF radio has a letter K in the position where a UHF radio has a letter R. For example,
AAH50RDC9AA2AN = UHF while
AAH50KDC9AA2AN = VHF
4helpful
3answers
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Is the motorola MU21CV a UHF or VHF??????
MU= UHF
MV = VHF
Best regards.
1helpful
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
1helpful
2answers
Compatability
would a MU21CV be a VHF or UHF????
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
