Remove the top thread completely from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Set the top tension at the midway point and then tweak it from there.
On my wife's machine, it was the clutch/freewheel coil spring making a chunching sound when it engaged each time. Any variation in lbs of thrust on each pedal stroke also made it crunch. This crunch is amplified through the body of the bike and becomes a clunk with each pedal stroke, and sounds just like a loose crank/ bottom bracket. I replaced the pedals to test and replaced the grease in the crank bearings/cups with Phil Wood grease, and agonized on the tightness of the cone on the crank before finding the real source of the noise. I allpied some grease to that clutch spring and worked it in a bit and there is no more clunk. Also, it is smoother in generat for my swapping out the crank bearing grease. Wife is happy. :-)
The direct link for the MWM 980 manual is: http://www.impex-fitness.com/images/mwm980%20manual.pdf . This manual has the parts list, assembly instructions and the weight resistance chart. None of the products have a model number starting with xj- .
Turn Player On Open Disk Tray (Leave Open) Using the Remote Control Press 3 5 9 7 3 5 Select 0 (Zero) For Region Free (MULTIREGION) or 1 ~ 6 For Region Specific if Required
