Health & Beauty Logo
Ruth Lee Posted on May 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get the 48v 500watt bushless motor for my e wheel E36 3 wheel electric mobility scooter
Joel Friedenberg
Level 3:
  • Master 1,114 Answers
  • Posted on May 01, 2014
Joel Friedenberg
Master
Level 3:
Answers
1114
Questions
0
Helped
440082
Points
3272
500 Watt 48 Volt Electric Scooter Motor
This link shows a 48 v. 500 watt motor, but you should contact them to make sure the motor fits your particular scooter. I hope this helps.....
  • Ruth Lee Mar 15, 2015
    Thank u u.help I will use u advise wisely
5 Related Answers
oregoon
  • 175 Answers
  • Posted on Jul 12, 2009
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Anonymous
  • Posted on Nov 25, 2009
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Anonymous
  • 61 Answers
  • Posted on Mar 19, 2010
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Anonymous
  • 3085 Answers
  • Posted on Jun 27, 2010
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Rich Miller
  • 46 Answers
  • Posted on Jul 11, 2010
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Mobility scooter reviews
I always check scooter reviews on this site: https://mobilityseeker.com/. They have the top 10 best electric scooter reviews and kicking manual scooter reviews for both adults and kids. Good luck with your research!
Upgrading electric motors
Cost around $850 for scooter, and a powerchair has two motors! So powerchairs will be more. email me at Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Owners manual for 500watt electric scooter
hi, what brand and model scooter is that ?
Regards
Rob
www.gewizrepairs.co.uk
Strider mobility scooter shows fully charged but will not drive forward or backwards.
may sound silly, but have you checked that it's not in freewheel mode, as this would prevent the motor engaging
1helpful
Rubbing noise from rear of scooter
Please check that there is no surface touching the tires of the scooter, second this can be some plastic on top of the wheels, also it could even be a harmless friction sound.
Thanks
3helpful
2answers
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
