SOURCE: Ink systerm failure for hp Photosmart C6380
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Oxc19a0023 INK System failure
TRY THIS
Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
Press and release the "OK" button.
Display should say "Support". Use the Right arrow Key to look for "Reset Menu".
Press the right arrow key to look for "Partial Reset", press 'OK'
The printer will go off and will power on by itself, else wait for 20 seconds and power on the printer to complete reset
reset process for c6380
SOURCE: ink system failure...Oxc19a0023
Call 1-800-HP-Invent. They will walk you through a procedure to reset the ink system. You'll need to get a senior tech to do it, and it's a 50/50 shot as to whether it'll fix it.
You may have to pay for this service if the unit is out of warranty.
HP will usually take your word as to purchase date initially, so if it's out of warranty, LIE...just be aware that they will only believe you once and you will have to provide proof of purchase to get any further service!
