SOURCE: Powerware 9120 DC Bus Fault Problem.
there is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
SOURCE: DC Bus Fault in Powerware 9120 6KVA
Honestly, the cost of repair might exceed the cost of a new unit. We can likely get any parts needed to repair the unit, but might not be the most cost effective solution. Might want to price around for a replacement unit. If you need additional assitance, please contact us.
http://www.gowithon.com
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
If UPS is displaying "Site Fault", it is doing its job correctly. You need to check the wall receptacle. Probably hot and neutral reversed, or the neutral and ground are reversed, by whom ever installed the wall receptacle. You need to have the plug-in for the UPS intact, i.e. the ground pin must not have been cut off. If an extension cord connects the UPS to the wall, thge cord must be working correctly.
