Your Motorola Razr V3m phone is free of any network lock,it will be run on AT&T network.If it's network locked one means,you will need to unlock it.You can unlock your phone by network unlock code.You can get an unlock code from your service provider or else try to buy an unlock code from any one of the online unlocking service provider like Mobile-Unlocker.com Here you can unlock your phone at low cost.
SOURCE: Razr V3M locked
Press and hold the * key then press the center button. It will ask for the security code and the default for it is 000000
SOURCE: How do I remove the Sim card from a Motorola Razr
hello
these are the steps to remove a sim card from motorola RAZR
step 1. Turn off your cellular phone by pressing and holding the power key for two seconds.
Step 2. Remove the battery on the back of the phone by sliding it back and lifting gently.
Step 3. Identify the SIM card, which is under the battery area. A retention strap holds it in place. Don't stretch the retention strap. Slide the SIM card slowly back, up and out of the slot.
Step 4. You may now use the SIM card in another phone, or insert a new SIM card into the Motorola RAZR
