Question about Frigidaire FAC126P1 wall/window Air Conditioner
My ac window unit does not seem to have any obvious drain hole or plug
DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
    Top Expert:
  • Frigidaire Master
  • 64,325 Answers
Yep agree nephew drill right into his coil and ruined 800.00 unit
Posted on Mar 20, 2015
6ya staff
SOURCE:
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
My window airconditioner sounds like it has water in it and now its spitting out water in the room?
This can be caused by 2 things:
The drain pan hole is clogged and water is backing up in the pan. Look under the outside part of the AC unit for the drain hole and clear it. It may be hard to find, as the clog will blend in with the hole.
The unit was installed incorrectly and the outside portion (outside the wall) of the unit is not tilted down 1/4" to 1/2". Which allows the water to run to the drain plug.
Correcting either or both of the above 2 things, should solve the problem.
Jul 15, 2011 | Haier Heating & Cooling
My frigidaire wall unit ac is drippijng water inside of apartment. i have used a level when it is out of the wall and it shows ac is tilted correctly to the b ack but when i put it in the wall the level...
The drain holes in the bacl are plugged with dirt...
pull the A/C out and check for the blockage and remove it so that the unit will drain properly.
The drain holes are usually in the back corners...
heatman101
Sep 24, 2010 | Frigidaire FAC124 wall/Window Air...
Ac is tilted out but water still drains in
Hi!!
Look on the bottom back of the unit for the drain hole is probably clogged, use a piece of wire to unplug it.
Don't forget to rate this post!!
Aug 28, 2010 | Frigidaire FAH106S2T Thru-Wall/Window Air...
Water leaking inward
There should be a drip tray that catches all the condensation and funnels it out the back. Check for holes, cracks or a plugged drain hole.
Aug 30, 2017 | Frigidaire FAC124 wall/Window Air...
My a/c is trwonig cold water and air
The water is standing in the ac unit and not draining out.Is this a window unit?Ac on a car or truck?If it is a window unit for a house,remove ac unit from window,and take out side and if it is in a cover,remove the cover to expose the ac unit,and it`s components.Wash out the bottom of the unit to uncover all the drain holes.Get all debri out of unit.Replace the unit in the window at a good tilt(tilt it outward)so it can drain good,and not back up in your house with water.
Aug 29, 2009 | Heating & Cooling
Installing a window A.C. unit by maytag
no it shouldn't matter,just insulate the gap so you dont loose cool air,as for the draining problem tilt it some more,and make sure drain hole is open and not plugged that should fixya
Jul 29, 2009 | Heating & Cooling
Leaking evaporator home ac NEW Amana unit
Friend,
Happy to assist you!
Why are you doing it?
You have a new warranty, call service and let them correct it!
You need to call service !!!!!!!!!!!!!
Aug 29, 2008 | Amana Heating & Cooling
Frigidaire FAC126P1 wall/window Air Conditioner Logo
953 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
