If this happens and you have an iPhone, you can try three things, 1). Make sure your phone has not been silenced. You can do this by checking the very top button on the left hand side of your phone, if the screen is facing you. If you're doing things right you should see indicators on your phone screen like "silent mode on" and "silent mode off".
2). Make sure the ringer volume is turned up such that you can hear it when someone calls. To check this go to Settings -> Sounds & Haptics then scroll down to ringer and alerts to adjust your ringer volume accordingly.
3). If you've tried 1 and 2 and your phone still isn't ringing when someone calls you, try turning your phone off, waiting 30 seconds, then turning it back on again.
If none of these things work, below is the link to a video with more ideas to try. Good Luck! :-)
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
This is as easy as any one can do go the main menu entertainment then select record sound and there you can start singing after finishing recording save the recorded file and then search the recorded file in the music go that file and select option then select use tone after that select as set as ringtone.Set the file then make a call to your number then there you can here your recorded ring tone.
var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Without having the programming manual on hand for this switch I have to generalize from other switches. Double check your auto forward settings within your hunt groups. It sounds like you have auto forward set wrong. If you have the voice mail set to engage on the 4th ring try changing that to engage on the 6th ring with the forward within a hunt group to forward to next available on the 3rd ring, see if that helps.
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
■ Do Not Disturb is available only on system telephones.
■ Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Since you declined to specify the model of your Uniden DECT 6.0 phone I can only suggest that you select it from the list beginning here to download a copy of the manual.
In ur mobile, there is a profiles folder.Just go into folder & select ur profile but before selecting it u have to edit it.
By editing,change the ringing type.
choose ring or max ring option & after that u wll definately get ur ring sound back.
