Question about KitchenAid 32685 Mixer
Why is my blender making a loud high pitched sound and getting hot?
Making High Pitch Noise, Sounds Strained
the drive shaft bush is dry ( probably from dough getting up the shaft) have the unit serviced /repaired and properly lubricated using food grade lubricate
Mar 20, 2017 | Bosch Food Mixers
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
I have a 6qt professional kitchenaid mixer and that I bought last year and have just recently started to use it but it make a high pitched squeal that makes it almost unbearable for me to use. If anyone...
Diane,
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... but alas they do not. So much for quality in America today!
Nov 02, 2009 | Food Mixers
525 watt mixers broken
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service here u go. Customer care will direct you to a certified kitchen aid repair shop in your area.
Apr 21, 2009 | KitchenAid KP26M1X Stand Mixer
We just got a 6 quart kitchenaid mixer, we have used it once and the loud high pitched sound is very irritating. Is this a problem that will go away in a short time, or do we send it back for repairs? Our...
Hi Wayne. If you want to keep the mixer, you'll have to buy some earplugs. Newer Kitchenaid mixers are all that noisy. The best thing that I can say about them, is that they've got great paint jobs. If you do keep the mixer, other revelations may occur later when the plastic transmission housing fails and possibly ruins your mixer. These units are poorly manufactured in my opinion. I know because I've been through my own Kitchenaid mixer rebuild. I recommend that you return it and consider an Electrolux DLX. My own solution was to buy a used commercial Hobart mixer and rebuild it. I am once again a happy man!
Good luck! ricardok45
Apr 20, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Jan 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
KitchenAid 32685 Mixer Logo
159 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
