SOURCE: KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
SOURCE: kitchenaid superba dishwasher does not pump water
Welcome to FixYa,
It may be a seized wash pump, worn wash impeller or simply a plugged up pump preventing a proper wash cycle.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It may not be your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
SOURCE: Kitchenaid dishwasher KUDP01IL upper spray
Just had the same problem, and fixed it. Spray arms turn with proper water pressure in the pipes. 3 reasons can lower the water pressure. 1-pump motor losing power (wasn't my case) 2- cracked pipe (wasn't my case either, pipes, although plastics, seem to be very solid) and 3- debris in the pipes/filters. (It was my case) At first, it looks difficult to reach de filters, but it isn't.
1- Remove both baskets, the top one by removing the front plastic cap on the rails.
2- Remove the "+" bottom spray arm, by unscrewing counterclockwise (if I remember well...) the plastic screw dead center of it (use your fingers.)
3- Remove the three screws you see, but don't try to remove the filter part right away because there is a 4th screw under the leading water pipe, the one leading water to the top spray arms.
4-To remove the 4th screw, you must remove the plastic pipe that connect with the top spray arms. Easy. It's beeing held there by two clips, one on the back wall and one on the top wall. Just spread them with your fingers (or screwdriver) and turn the pipe toward the right side, to free the bottom part of the pipe from the middle/bottom spray arm holder, you'll have to bent it a little so it passes over the heating element.
5- Remove the last screw. Now there's nothing holding the bottom part anymore. just remove by moving it back and forth left and right (to loose it up), be carefull not to lose the clear plastic washers on the main shaft when removing. Now if your dishwasher is like mine (should be) you should see a lot of debris that couldn't reach the chopping device. In fact, the water couldn't flow properly because of all the debris stocked there by the bottom drain filter. Patio screws (?) small chicken bones, etc...
6- If you can find something to pump the water resting at bottom there, (I used a Prestone coolant tester!) you'd have a better view, and could remove the single screw holding the chopping device cap in place. That's the last step. Notice that the chopping device cap, even after the screw is removed, still look like firmly attached, like "glued", but there's absolutely nothing else holding the cap. Just shake it with your hand and it will eventually come off. Now you remove all the dirt/debris you see there, and then follow thw step back the rebuild the washing machine. On my part, it brought it back like if it was brand new..., but, now I'm being a little more carefull about the stuff I'm putting in there...
I hope it can help, English is not my first language.
Good luck
Daniel
Montreal, Canada
SOURCE: I have a kitchenAid KUDS24SE - BL3 s=dishwasher.
Hello, tina
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
