SOURCE: to solve motorola v360 storage device
i had the same problem if your memory card is over 150mb then it is to high a memory for your phone you can buy a 150 mb memory card in your local phone shop
SOURCE: motorola v360
IME-359196005331718 the thief stole my sister's phone and it was recovered and he had changed the unlock code maybe even the security code Iam not sure about it. Could you please help me I am in deep trouble I need to use my phone.
SOURCE: motorola e815 CDMA cellular phone unlocking software free download
The Motorola E815 is a CDMA handset. CDMA (code division multiple access) is a digital service only provided in the United States. Unfortunately, CDMA handsets will only work on CDMA service. Therefore, the phone you are referring to cannot be used overseas.
GSM (Global System for Mobility) phones are the ones that can be unlocked to provision for different SIM cards. Once a GSM handset is unlocked, or "unbranded", it can be used with any GSM provider's SIM card.
Sorry for the bad news, but your E815 will not work in India.
Please rate as at least helpful, as there will be no Fixit solution for your situation.
SOURCE: Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
