Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what
could be done is to purchase a phono to line level pre-amplifier to go
along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either
should be relatively easy to work on and perhaps you can try the
services of a locally available qualified electronic technician since
the repairs would not be too specialized. The
service manual may be of help (or at least a schematic , they may be downloaded from
here and
here).
B. To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i.
Onkyo TX-8522 Stereo Receiver;
ii.
Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii.
Sony STR DE695 AV receiver;
iv.
Teac AG-790 200 Watt Stereo Receiver;
v.
Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a.
XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro
PP999 Phono Preamplifier;
c. Pro-Ject
Phono Box Turntable Preamplifier;
d. Radial
J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
The turntable is not grounded to the receiver. Would grounding it make a difference? I hooked up the turntable directly into the wall with no difference in the buzz at all. If I need to ground the turntable to the receiver, do I need to do it anywhere specific? There is no specific ground on the turntable or the receiver. Thanks for the help!
