SOURCE: kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
SOURCE: One of the handles on my Kohler faucet does not
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
SOURCE: KOHLER SINGLE HANDLE FAUSET DRIPS
Replace both Kohler faucet cartridges. You can get free replacements from Kohler. Their faucets all come with a lifetime warranty.
i'm w/ya. got the handles off and the replacement cartridges - can't figure how to loose the nut holding the cartridge in place
