Mitsubishi VS-50609 50" Rear Projection Television Logo
J
Joseph Garagozzo Posted on Apr 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit comes on for 2-5 sec. then shuts down
Unit comes on for 2-5 sec. but then shuts off to stand by, can you help
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on May 08, 2014
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35518
Points
350
Probably has lost convergence chips and fuses. But keep in mind--these sets often get a LOT of capacitor problems and fulid leakage problems too--so be aware of this.
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
2answers
Computer will not come out of hibernation
press and hold the power button for 30 seconds.... this will remove any static electricity in the computer.... now restart again and your issue might have sort out....
22helpful
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
1helpful
The screen shuts down after between 30 & 60 secs
This is an option for the TomTom. If you enter the Options, there should be something about Power Save features. In there, you will see options to shut off the screen, and you can have it do so after a certain time, once a certain speed is reached etc. Just change the time in which it turns itself off to never and you're fixed.
WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
2003 Honda Pilot a/c compressor stopping after 2 secs.
If i was guessing on this problem i would say that the pressure switch is malfunctioning and telling the computer to shut the a/c down. It could be a power stearing or a throttle switch as well.
4helpful
3answers
HOW TO RESET LAMP HOURS AND THE PROJECTOR WONT FIRE UP,STAND BYE LIGHT IS ON.sHOULD i LEAVE THE UNIT OFF FOR A WHILE THEN TRY AGAIN.I HAVE JUST REPLACED THE BULB AND I THINK WHEN IT KNOWS THERE IS A NEW...
From the booklet that comes with the replacement lamp:
1 While holding down the "MENU" and "ON/STANDBY" buttons simultaneously.
2. Insert the power cord
Not great English, but I tried this yesterday and it works.
My laptop turns on itself, i don't know what's causing it. my windows(service pack 2) is fine and running smoothly....
Go to control panel. Power options and there u can see hibernate. enable hibernate and click apply. and come out and go for shut down and there u can see stand by shutdown and restart. then press shift button on keyboard the standby turn on to hibernate. then click hibernate it will shut down the entire system within 10 to 15 Sec try this. and Mail me on this mail ID
[email protected]
Power shuts off after 2 or 3 sec.
please remove all speaker from receiver-volume down and test if the receiver shut down it needs to fix in service center-if not insert speaker one by one until you find the bad one-change its cable first and then change speaker itself.
2answers
Downloaded 1 CD to Bose 3 2 1. Now system is stuck in continuous rebot mode.
There seems to be some large problem with the drive, where an obstruction within the drive pops up. The solution is to return it or repair it for a new unit. I am disappointed with the Bose team on this one, let's be SURE. So your bet is to steer clear i suppose! maybe try a reciever based Sony HTIB? Thanks! Good Luck!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
