Check to make sure that the spark plug wire was put on the spark plug all the way. You need to gently push down until you hear a little click (the metal in the spark plug wire and the metal on the spark plug connecting). If that doesn't work, check to make sure the spark plug is screwed in all the way.
Its also possible that when the spark plug was taken out it was damaged. If none of the other stuff works, try replacing the spark plug.
CaN that make te car over heat, also what\'s wuld happen if he pushed really on hard on one?
No, your spark plugs will not make it overheat. If he pushed really hard on the spark plug while screwing it back in, he could have stripped the threads (a really bad problem). If he just pushed hard on the spark plug wire when he was trying to put it back on, he might have broken the wire. Was it overheating before you took the spark plug out?
No, he did put oil in b3fore we drove, the putti?g getting worse and made a wei4d noise once?and th oil is really thick
What can the problem be
Based on what you're telling me it could be a lot of different things. The putting noise you're hearing could be a cylinder misfiring, which could be cause by a lot of different things. The thick oil and overheating makes me think that something is seriously wrong though. You need to have that looked at. The spark plug has nothing to do with that, and it needs to be fixed asap
SOURCE: 318is 1997 e36 m44
If there is a ticking noise on the engine it may be that your engines hydrolic valve lifter's may be failing. The reason why it may be a running problem is that the valve lifters are part the VANOS system witch is BMW's answer for variable valve timing. you have the M44B19 engine witch only has VANOS on the intake cam shaft. I cant be shure with the infomormation I have if this looks right and you require more assistance.
Please Ask.
SOURCE: 1999 Mazda Miata Problem
I have driven Mazdas for 25 years, and am sharing these experiences in case they can help anyone. I had two RX-7s and then bought a 2004 Miata a year ago. The Miata really was brand new, a showroom car with minimal miles on it--truly mint, and a true dream come true.
It ran perfectly but the 'check engine' light kept coming on. The owner's manual lists four possible reasons: 1) fuel tank level being very low or approaching empty; 2) electrical system has a problem; 3) emission control system has a problem; and 4) fuel-filler cap is missing or not tightened securely.
Given the car's brand new condition, and since it had a full tank of gas courtesy of the Mazda dealer, I could rule out 1 through 3. That left the fuel-filler (gas) cap. I had driven the car minimally the first month, so the gas tank was still almost full when I took the car back to the Mazda dealer. When I was instructed about the importance of making sure the gas cap was secured tightly, I said, "Interesting you should mention that, since I haven't touched it since I bought the car, so if it isn't properly affixed, guess who did it?" and laughed. I asked if it was a "software" glitch between the updated software used in the shop's system checking equipment and the fact my car was three years old. That resulted in a stunned look. I barely had finished a small cup of coffee when the manager came to tell me everything was fine. The answer about what was the problem was vague, at best. Zoom-Zoom, off I went, and the 'check engine' light hasn't appeared since then. I do find the gas cap difficult to manage, especially in the winter.
The Bose CD player died last week, but that's a different problem! G-R-O-A-N.
I am a huge fan of Mazda. Of course the RX-7s had the rotary engine and the Miata does not, but there are similarities. These cars dislike condensation. I am in the northeast where winter temperatures reach minus ten or lower, and where summers are very humid.
I went through the spark plug changes and all else with the first RX-7 when it seemed to have a problem misfiring, or not making a solid connection. It had a manual choke, so starting it was easy, but after it was warmed up and ready for takeoff, it would perform as if it had a short or dirty plugs or something.
I was religious about having the oil changed every 2,500 to 3,000 miles, very important. When it seemed the car was misfiring or just not connecting on some level, and everything checked out perfectly mechanically and electrically, I decided to try two things. First, I only used the best gas. Expensive, yes, but the car performed better and got better mileage. Second, I always kept a bit of dry gas in the tank, all year round. When I had the second RX-7, I lived near a lake and there always was heavy mist and condensation. If I kept dry gas in the RX-7s, they didn't have a problem. If I forgot, the response was chugga-chugga-chugga, cough, spit, hesitate, misfire, and generally behaving like a misfit.
I should stress I ONLY am talking about dry gas, sold everywhere in the northeast during the winter, even drug stores and supermarkets. There are tons of additives on the market that claim to do this and that and I never have used any of them.
We love these cars because we feel one with them. They are so beautifully engineered, we notice every nuance, every single thing that seems a tiny bit off. The best advice I can give anyone about these great cars is to trust that knowledge, and to be persistent if you know something is not quite right, no matter what someone tells you to the contrary. I wish everyone as much joy as my Mazdas have brought me . . . now, on to that Bose problem . . . how I landed on this web site in the first place.
SOURCE: check engine light comes on and car idle's and
I found this; if it helps.
The injectors need to be cleaned, if an engine is experiencing any of the classic symptoms of dirty injectors, such as lean misfire, rough idle, hesitation and stumbling on light acceleration, a loss of power, and higher hydrocarbon (HC) and carbon monoxide (CO) emissions.
Lean misfire may also trigger a misfire code and turn on the Check Engine light on 1996 and newer vehicles with OBD II systems. The code often will be a P0300 random misfire code, or you may find one or more misfire codes for individual cylinders, depending on which injectors are most affected.
the web page was:
http://www.aa1car.com/library/2003/ic30336.htm
Hope this helps
SOURCE: 1997 lincoln continental check steering assist light
Is the fluid full enough? there should be a dipstick to tell where the level should be. Also is the belt tight enough? Wires loose?
SOURCE: 2000 Lincoln LS--Check engine light blinking/sputtering take off
Hey I have the same problem...i changed all 8coils and spark plugs. But now when I start the car sometimes it stutter(shaking), but once I pass 3rd gear it drives fine, the engine light was blinking, then stayed on..but I disconnect the battery to clear it. Would the car shake if your low on fuel?
