Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Look in the menu to see if in catv or cable band or air band for antenna and you do have a way around this if using cable box or sat box---connect box via the jacks on the rear of the box (component or composite--component being better) and hook up to the correct matching input on rear of set--select that input on the set and change channels etc via the box.
Also try to unplug set for a short time and go through the setup again, be patient as a channel scan can take several minutes in some cases
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
the programming should be automatic...it will seek the channels and put the active stations into memory. when it is done searching it will come back to a channel...this can take up to 30 to do because there are several TV broadcast bands it has to look through now. as a last resort, unplug it (power) wait a few seconds , then plug it back in and start all over (reboot)
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Go in to ur tv menu.Go to SETUP go down to CH.press it,pick AIR not CABLE.Press for scan for free air channels,wait when it finish scanning.U should get all free air DTV channels.
U planning to get free air tv?No need for a converter box,ur tv have digital tuner inside.Just plug in ur antena.Go to ur tv menu go to setup pick air scan all ur channels,well get all free air channels.
