Open sub
SOURCE: JBL Creature doesn't work
make sure the triangles on the plugs are lined up when you push in the plugs!
SOURCE: JBL Creature 2 Blowing Fuse
I think you made a mistake with your fuse.
With my JBL i can see 9,5A 41FU.
SOURCE: JBL Creature -- speakers only work when directly connected
Check that you are fitting the connectors into the subwoofer correctly.
Each plug is keyed (the plug is shaped so that it will only fit into the correct socket).
It is very easy to think you have plugged them in when in reality they are just 'located' in the holes.
SOURCE: this thing isn't build with jbl speakers!
JBL is obviously just putting their name on your product. Just the way it is. They put their name on it, but use inferior parts. It is cheaper for JBL to have other folks make the stuff.
