Measuring Tools & Sensors Logo
R
Rob Hall Posted on Apr 30, 2014
I'm looking for operating instructions for a Professional Wireless Weather Station with Outdoor Sensors WH5302
  • Rob Hall
    Rob Hall May 01, 2014
    btw. It looks like this.
  • Rob Hall
    ...and has a small Solar Charging Panel fitted to the unit.
rick osborne
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 30, 2014
rick osborne
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1984
Points
Go on e-Bay, look up weather stations, and send a note to tech support via e-mail to Raul. He seems to care about issues with the DR Tech weather station (I've had many, issues and weather stations!). Rick
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Aug 30, 2012
SOURCE: Select a weather station
Davis is most reliable even with isolated incidences
Anonymous
  • Posted on Nov 07, 2011
SOURCE: wear can i go to print off instructions for my
http://www.lacrossetechnology.com/8300/index.php
The Archery Clinic
  • 305 Answers
  • Posted on Dec 02, 2010
SOURCE: My Nexxtech wireless weather station
You must move the remote sensor close to the base unit to reset it and it will work fine. After it shows the temp then you can move it back to its location. thanks for asking at Fixya.com.
Anonymous
  • Posted on Dec 08, 2012
SOURCE: the sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
  • 19187 Answers
  • Posted on Mar 10, 2013
SOURCE: Taylor Wireless Weather Station With Clock model 1506 Instruction manual
http://www.taylorusa.com/taylor-support
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
Ascot Weather Station. Instructions for operation please?
Ascot weather station manuals
Manua.ls https://www.manua.ls > Ascot > Weather station
You are currently on the Ascot weather station manuals page. Choose one of the products to go directly to the manual for this product.
Ascot weather station user manual
Manuals.co.uk https://www.manuals.co.uk > Ascot > Weather station
For those looking for a simple and straightforward setup, Ascot Weather Stations provides a quick start guide with step-by-step instructions to get you up and ...
User manual Ascot AUK-WS-32 (English - 6 pages)
Manua.ls https://www.manua.ls > weather stations > Ascot
To install and set up the Ascot AUK-WS-32 weather station, you should begin by securely mounting the sensor unit in an elevated outdoor location, ensuring it is ...
Ascot GT-WS-06s user manual (English - 40 pages)
Manuals.ca https://www.manuals.ca > weather stations > Ascot
User manual. View the manual for the Ascot GT-WS-06s here, for free. This manual comes under the category weather stations and has been rated by 2 people ...
Ascot Weather Station User Manuals Download
ManualsLib https://www.manualslib.com > Brands > Ascot Manuals
Download 1 Ascot Weather Station PDF manuals. User manuals, Ascot Weather Station Operating guides and Service manuals ... Operating Instructions Manual.
Ascot Weather Station. Instruction for reset times please.
Can I download an owners manual for a dr tech WF-1070T outdoor sensor?
Not found it so far but here is a book for a 1050 model, much of which is transferable. There is no Dr. Tech website per se where you can get support or download a manual. That means you would have to depend upon hobbyist/blogs or look up information in generic sites about factors in weather if you have a question. Here is a site where you might try some queries:
http://www.weather-watch.com/smf/index.php?topic=53707.0
http://site.ambientweatherstore.com/Manuals/wh1050.pdf
https://www.rakuten.com/prod/dr-tech-professional-wireless-weather-station-w-solar-transmitter/230818678.html
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
1helpful
2answers
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
