I would suspect the float first, IF the unit is level. But it could also be blocked with gunk and you will need to check the drain holes. I have always found a guitar string is an affective clean out of drain lines and holes.
The orange light indicates that your bucket is full, so if it isn't then it is most likely the float above.
I had this problem. 1 day it was working then it wasnt. Re format it in windows as NTFS then move it to your psp and reformat it there. Hope this works for you
yellow wire - continous power
red wire - power ( when switch is on)
black wire - ground
blue wire - remote ( has power when switch is on) ( must be connected)
blue/light blue - rear right speakers
yellow/brown - rear left speakers
white/white striped - front left speakers
grey/pink - front right speakers
orange wire- dimmer lights ( not important)
these are the wires coming from car follow this diagram and you should be fine
