Need parts diagram
Wahl Stable Pro parts diagram - Fixya
www.fixya.com/support/t24287858-wahl_stable_pro_parts_diagramApr 30, 2014 - SOURCE: How to reassemble blades on wahl stable pro 8800. Do you havemore parts in your hand than 2x screws and 2x blade parts?
Parts diagram wahl 9639
Jan 20, 2014
wahl mc2 parts diagram Questions & Answers (with ...
Feb 21, 2011
parts diagram wahl 9639 Questions & Answers (with ...
Nov 25, 2010
SOLVED: Need wahl stable pro parts
Nov 23, 2009
More results from www.fixya.com
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
