Syed, Possibly you mean traction control light.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
www.yourmechanic.com > Auto Repair and Maintenance Services
As a result, sometimes an issue in the ABS can trigger the traction control light. If this is the case, then both the ABS and Traction Control lights will be on.
Oct 16, 2006 - I drive a 2000 chevy impala...i have 135,000 miles on my car. ... The problem is that starting in '92, Anti-Lock Brakes are controled electronically, so if there is a problem with the sensor, your ABS might fail when you need them the most. ...ABS (?nti-lock Brake System) is a ...
? 5:35
https://www.youtube.com/watch?v=KFQphWamcjQ
Feb 17, 2014 - Uploaded by Zero Gar
How To Fix ABS & Traction OFF / Service Traction SystemLight Monte ... side connector that leads from the ABS controlmodule to the speed ...
It is very common for all of these lights to come on all at the same time. They are all related to your Antilock Brake and Traction control system. ABS = Antilock Brake System, TRAC OFF = the traction control system is disabled - either because there is a malfunction in the ABS system or you have turned off the traction control button. VSC = Vehicle Skid Control. - (which uses the ABS and the Traction Control to function.)
The most common cause of these lights coming on is one or more defective wheel speed sensors. Although there are many other possible causes as well. Your ABS and Traction Control system must be scanned for fault codes to diagnose the problem. If you had damage to your wheels/axles during your "fender bender" this may have something to do with it. Otherwise it may just be coincidence that part of these systems failed right after your accident.
The ABS and traction control system are the same system, when the light came on it means the ABS/Trac control module has sensed a fault in the system, that can be one of the many components or the wiring or the hydraulic control unit, in order to find out what has failed the ABS module needs to be tested for a fault code that is stored when the light is turned on, the dealer has the scanner to do this test.
this means the ABS/Traction Control system has been diabled and all u have are regualr brakes without any traction control have the dealer or a brake shop test the system, there will be a system fault code that indicates where to look for the problem part or wiring.
Hi there.Whats happening here is an abs sensor in the wheel has failed.In doing so it will turn off your traction control because your abs breaks and traction control work together .If maybe you have an auto zone near by they can scan your break system to find what abs sensor is causing the problem.I hope this clarified some for ya..Auto zone will scan the car for free so that won't cost you anything.You can drive the car you just wont have abs and you should get it fixed.Again I hoped I helped you and if you need further assistance I'll be here to help you..Have a great day..
It is one of your wheel bearings. The problem is easily solved by taking the car to a dealer, or having a code reader, and determining which wheel bearing is bad. The wheel bearing is under $150 and should be installed by someone with some muscle, as the bolts are torqued from the factory extremely tight in a tight location. The wheel bearing have all of your sensors for abs built into them and if that sensor goes out your computer tells the abs and traction control to shut down, hence you get the lights on on the dash.
