Question about Jugs Toss Machine A0600
Where to get a Motor for a Jugs Toss A0600
Where to get a replacement motor (JS-2330D12A DC12V CCW - 20031025) for this machine
2 Suggested Answers
SOURCE:
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
Need to replace drive motor. Which one to buy CW or CCW
That depends on if your machine has a separate water drain pump. Most washers use the same motor to run the agitator then the motor runs in the opposite direction to pump out the water.
Dec 18, 2015 | Washing Machines
Rodent chewed off motor wires
Have to get wiring diagram or someone local same machine have a look at wiring on neighbours
Dec 01, 2015 | Washing Machines
Jugs 101 pitching machine , bottom motor will not run ,no current at connector on circuit board
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Jul 21, 2011 | Jugs Baseball 101 Pitching Machine
When in operation the machine itself is out of balance.
pull off the wheel and run the machine. you will be able to see if the hub is out off balance. if it spins true the you have a rim or tire out. this can be fixed by having a tire shop balance it for you or call Jugs and get a complete replacement,tire and rim ,shipped mounted and balanced.
it is very unlikely that the motor shaft is damaged unless it was droped trying to load it into a truck.
it most like;y is the tire and rim that is out
Nov 29, 2010 | Jugs Small Ball Pitching Machine
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt...
Hey gunsmoke55,
Let’s collect some info. and I will try to help. I own the FAV6800A the LED flavor of the machine and as you can tell from my nick name I DIY all repairs on the machine.
1. Did your FAV9800A signal an unbalance statement to the display to trigger the clutch replacement?
2. How badly rusted up was the One-Way Roller clutches bearing? Did you follow my clutch maintenance/repair post to replace your new clutch? Clutch Fix Post .
3. When you removed the original clutch did your series of the machine use the Upper One-Way Roller clutches bearing ring? From pulling info. from other FAV6800A owners I have been able to confirm series 10 and 11 used the Upper One-Way Roller clutches bearing ring. Info from FAV9800A owners is very lean. What is your series of machine (the first two digits of your serial number) and did it use the Upper One-Way Roller clutches bearing ring?
4. You should be able to rotate the wash basket with one finger CCW with very little resistance. Try that and let me know if the wash basket will rotate CCW with one finger . The wash basket must not rotate CW by hand. With the front cover removed (pull the 120VAC power cord) you should be able to rotate the Clutch Pulley CCW and CW with light resistance.
“”I just replaced (new) the clutch on my FAV9800AWW, and machine goes through most of regular cycle, but at some point (reverse or tumble?), it tries to do something between the motor and clutch and the belt just squeals very loudly and burns. Ideas? SW””
If you machine used the Upper One-Way Roller clutches bearing ring it may not be seated in the wash tub base properly. It is a very tricky fitment process to re-install it and the Clutch Pulley assembly correctly. Let me know what you find and we will go from there.
Some insight into normal operation of the machine you may be aware of this; In the wash/agitate cycle the Control Board signals the Motor Control board to power the Motor CW turning the Clutch Pulley CW driving the agitator shaft which drives the transmission to rotate the tumblers only.
In a Spin Only cycle or the Spin Cycle of a Wash Cycle the Control Board signals the Motor Control board to power the Motor CCW turning the Clutch Pulley CCW. The One-Way Roller clutches lock up solid driving the Spinner assembly CCW spinning the wash basket CCW. When the One-Way Roller clutches do not lock up rock solid and slip you get tumbler movement as the wash basket begins to spin up. This causes the wash basket load to go off balance and if the TDS is working properly it’s signal input to the Control Board exceeds design limits of Outer Tub movement and the Control Board fails the Spin Cycle wit a dC or uC unbalance error or in your case an unbalance statement to the LCD display.
Also during the initial water fill cycle of the wash cycle the Control Board will signal the Motor Control Board to power the wash basket CCW slow RPM. I believe the Maytag design team did this to wet the wash basket load on initial water fill…..Rich 5a647fe.jpg
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Shows code lr works sometimes ,makes pssssst sound like a shot of air
I have seen this code caused by a failed Motor Controller, a failed Control Board and one forum member replaced the TDS sensor to clear it.
This could be a difficult issue to troubleshoot if you don’t have replacement parts.
If you want to get into this you could remove the machine front cover and check to see if you can rotate the clutch pulley CW and CCW with no binding. I would have you start a Spin Only Cycle and see if the Motor will drive the Clutch pulley CCW. If you decide to call in a repair service call Maytag 800-688-9900 to get an authorized warranty repair service company. The control board has a 5 yr warranty, motor has 10 yr coverage. The warranty info is in the SM. Maytag will need your model and serial number. That info is located on the back right top side of the console.
The Service Manual for reference. Sears Parts Direct for reference.
Good luck
Oct 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machine won't turn on
the rating, is that the same with the original one.?
try running with no load, maybe the motor got problem. if okay no load. try run with a little load. if still blow the fuse even no load test. Your problem is in the motor. Or monitor carefully when the fuse blew, is it when the motor run ccw or cw?
Jun 10, 2009 | Fisher and Paykel (IWL12)
Jugs Toss Machine A0600 Logo
537 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
