Toshiba Satellite A105 Notebook Logo
A
Anonymous Posted on Apr 29, 2014
How to get to the bios screen on my toshiba sattillite with windows xp media edition
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Nov 20, 2007
SOURCE: Toshiba Satellite 105A speakers/volume
Task tray menu usage You can turn on and off the features by right-clicking on the TOSHIBA Virtual Sound's task tray icon. You can also select a listening mode with this menu.
Task tray icon menu (Off)
Task tray icon menu (On)
Listening environment menu
Task tray appearance The task tray icon will blink when an audio filter is running. If you move a mouse cursor over the icon a pop-up message appear, then it will show a state of the audio filter.
The message which will appear when the SRS WOW HD is available
The message which will appear when the SRS TruSurround XT is available
The message which will appear when the SRS Circle Surround Xtract is available
Anonymous
  • 2028 Answers
  • Posted on Aug 21, 2008
SOURCE: Proplem Installing Windows XP Home media edition
Unfortunately, you will need to purchase another operating system disc, even though you have the product key. That key is assigned to the disc that came with the machine. Why exactly did the Xp disc of your father's not work?
mitch_3020
mitch_3020
  • 70 Answers
  • Posted on Oct 23, 2008
SOURCE: Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Nixcroft
Uwe Klopfer
  • 137 Answers
  • Posted on Nov 21, 2008
SOURCE: bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Anonymous
  • 92 Answers
  • Posted on Nov 07, 2009
SOURCE: blue screen with windows xp can't boot from cd
Most toshiba will boot if you press F12 and a boot screen will appear . the bios is most of the time acessed through F1 or F2 try that and let me know what happens
Blue screen with windows xp can't boot from cd
I have a HP Media center pc and I tried to up date BIOS which did not work turn off my pc and then came back on with a black screen get the message need system disc put the windows xp but nothing happens
make it clear what is the exact problem weather the sys. is not turning on or it turns on but you are not able to boot if your are not able to boot what is the error and when do you get the error message.and why did you update the bios??
Here's the info....
The term you posted, (AWRDACPI model) - AWRDACP, is the name of the bios.
If your motherboard model number is the Intel D915GAG than click on the link below;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1672&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Support for, Windows* XP Home Edition, Windows* XP Media Center Edition, Windows* XP Professional, Windows* XP Professional x64 Edition
Mike
2helpful
Using recovery disk on toshiba satellite p25 when dvd doen't work
if you had your windows XP media bootable edition... use it to format you Laptop...
note: after you format your laptop your files will be deleted... so make a backup as much as possible for your important files
Emachine microsoft Windows XP Media Centre Edition 2005, Re-install operating disc when used for firsttime will not function. Any ideas please Paul
is your computer set to boot from cd/dvd if not set it to do so from the bios. check boot screen for key to press so bios setup starts
4helpful
3answers
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Window XP Media Center Edition won't boot up if Brother MFC-440CN is connected.
I would go first with Brother's support suggestion. You can always go back to the original BIOS setting.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
