SOURCE: How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was
manufactured from the serial number on the back or bottom of the
turntable. SL-1200 serial numbers are in two different formats,
depending on the date of manufacture. It isn't exactly possible to
determine the decade in which the SL-1200 in question was manufactured,
as the serial number contains only the last digit of the year. If the
year digit is 8, the turntable may have been manufactured in 1978, 1988
or 1998. If the year digit is 0, the turntable may have been
manufactured in 1980, 1990 or 2000. One rule of thumb is that
old-format serial numbers belong to SL-1200s manufactured during the
1970s and 1980s, while new-format serial numbers belong to SL-1200s
manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These
serial numbers contain no indication of the month of manufacture. It
should be noted that serial numbers in this format contain no letters
following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while
the month of manufacture is indicated by the letter following it.
Months are coded as letters between A and L inclusive; A indicates
January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and
early 80's have a 4 inch diameter plate where the RCA and ground wires
enter the chassis in the rubber base of the unit. The later models have
a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
SOURCE: Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
