Sony Ericsson XPERIA X10 Cell Phone Logo
A
Anonymous Posted on Apr 29, 2014
How to clear sony xperia j recycle bin - Sony Ericsson XPERIA X10 Cell Phone
How can delete empty pages in the home screen from sony experia ST25i
Just long press it and when it is highlighted or prompted drag it to below Recycle Bin.
That's it.
I'm from oxford and I have recycling that won't fit in the recycling bin, what should I do with it?
from their website:
You can place extra recycling neatly at the side of your recycling bin in the old recycling boxes, a cardboard box or a clear plastic bag. Please do not use black bin liners.
May 07, 2013 • Home
I accidentally remove my recycle bin from the homepage . I need to restore it I don't see it anywhere in my computer though. Side note I do not have internet will I needed in order to restore it?
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Change desktop icons, and then do one of the following:
    • To remove the Recycle Bin from the desktop, clear the Recycle Bin check box.
    • To display the Recycle Bin on the desktop, select the Recycle Bin check box.
  3. Click OK.
I accadently deleated a school video from my phone its due tommarow and i NEED to retreave it please help. this was sent on 3/20/11
hi, there is no way it can be retrieved. there is no recycle bin and there is not undo/restore
sorry.
from lewis
portsmouth, UK
2answers
How to install back the recycle bin icon how to erase download files in recycle bin
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box.
  4. Click Yes when you receive the warning message, and then click OK to close the Folder Options dialog box.
  5. Click Folders on the toolbar.
    Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons.
  6. In the left navigation pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop.
  7. On the Tools menu, click Folder Options.
  8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.
I deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
I have a gateway laptop model solo 9500; 526 MB it move slow and I would like to add at lease one GB of memory or one GB of ram which ever will solve my problem. And also I would like to know how to delete...
Increase u r Memory or RAM to 1GB no problem .it will make the system faster and accessing the applications will be fast
See do u want to delete history of u r Browser ? for that just open the Internet Explorer Browser
Go to ====>TOOLS
=====>INTERNET OPTIONS
=====>Delete Cookies,Temporary Internet Files,Clear History
========>APPLY and OK
If U r Using Mozilla Fire Fox open u r Browser
Go To ======>TOOLS
===========>Clear Private Data
===========>Select all the Options and
===========>click on clear Private Data
if u r Browser is in Recycle Bin then
===>Right Click on recycle Bin
====>Select Empty Recycle Bin
2answers
Recycle bin
2answers
Recycle bin got deleted
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
