Hp 7210xi officejet printer makes odd sound after short power surge and is not responsive until I unplug it. when I plug back in the sound continues. How can I reset printer? I have tried plugging directly into wall receptacle. There is a black box type external power supply and appears to have no light on it at all. Thanks
SOURCE: HP Officejet d155xi
It sounds like you've done all the troubleshooting properly. I would contact HP or search their website for other users that have had similar problems. Also might be a good idea to check HP's site for new drivers, they change almost daily :)
SOURCE: printer alignment
hold down the enter button for 5 sec. then simultaneously press the menu button
SOURCE: hp officejet d135 series printer
Could be the printer carriage is binding, oil the rail and try again.
SOURCE: hp printer needs help
Remove the cartridges . and reinsert cartridges .
Ithink it will solve reset problem.
rafique
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps. Sorry, I accidentally posted this in problem section.
