Mirror locked up and will not change or allow mirror lock option
SOURCE: D70 mirror lock up
I'm looking for the source of this same problem. I was able to get my d70 unstuck by:
1. Set to full manual mode.
2. In the menus set mirror lock up to yes and then press shutter release.
3. Turn camera off and then back on
Hope this helps you!
SOURCE: fEE error code on nikon d80
To solve this all you need to do is turn the lens' aperture ring (the one nearest the camera body) to the smallest number (probably 22 or 32).
SOURCE: err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
SOURCE: Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
