Tears timing chain ajuster off nissan1989 four times
I'm assuming that you are talking about 1989 Nissan Truck 4WD 3.0L FI 6cyl.
In this models, the Z24i and KA24E engines do not use the pin counting method for finding correct valve timing. Instead, set the timing chain by aligning its mating marks with those of the crankshaft sprocket and camshaft sprocket. The camshaft sprocket should be installed by fitting the knock pin of the camshaft into its No. 2 hole. On the Z24i engine, the No. 2 timing mark must also be used.
Excatly, what is the problem? Adjuts timing procedure?
