TYC Condenser Cooling Fan Assembly, Toyota Avalon, 2000-2004 Logo
Stephen Posted on Apr 30, 2014
Where is the cooling fan relay at on a 2000 avalon
Rasheed Bashirov
Level 1:
  • Contributor 30 Answers
  • Posted on Jul 16, 2014
Rasheed Bashirov
Contributor
Level 1:
Answers
30
Questions
0
Helped
8445
Points
55
It could be located in one of the fuse boxes under the hood. Search ebay for "toyota cooling fan relay" you will see all the images of all possible relays. It could be an amplifier relay from under the dash or two relays (low fan and high fan) relays under the hood. See what matches your problem. Always read the diagram on the back of the fuse box cover to match the fan relay.
Where is the cooling fan relay switch located on a 2000. Chevy venture
Which one ? your van has three cooling fan relays an two fans ! The relays are located in the under hood fuse box # 9, 10 , 12 ! Relay Driven Dual Cooling Fan Diagnostics
2answers
WHAT CAUSES A P0481 FAN#2
most likely a bad fan motor or an open circuit.
Where is the cooling fan relay to a Toyota avalon
did you first spin the fans by hand to see if they move freely?
1helpful
Cooling fans won't run
Check the cooling fan relays,and the fuses,also if the thermostat is stuck,the coolant sensor will not sense the hot coolant,and will not activate the relay that turns the cooling fans on,also,if the coolant is low,or has air in the system it will do this also.
1helpful
Headlamps inoperative daytime running lamps come on then go out jumped out headlamp switch ground circuit out still no headlamps.
It sounds like your DRL RELAY/Headlight relay. I had this happen with a 2000.
Please rate me if this helps You.
Here is some info that I hope is helpful to you.
This first part is how to disable the DRL
TOYOTA. From the Toyota technical service bulletin EL011-00 Web site for specific models determine where the module is; either the DRL relay or the body ECU, connector number, pin #. Oct 6,2000.
Avalon 1999 DRL relay D4 pin 1
Avalon 2000 body ECU B5 pin 6
Camry S/D 99* DRL relay D6 pin 23
Camry S/D 00* DRL relay D6 pin 10 *twilight sentinel
Camry Solara99/00* DRL relay D6 pin 23
Celica 2000* body ECU B6 pin 17
Corolla 99/00* DRL relay D3 pin 23
ECHO 2000 DRL relay D2 pin 12
4Runner 2000 DRL relay D8 pin 2
Land Cruiser 99/00 DRL relay D8 pin 2
MR2 Spyder 2000 DRL relay D2 pin 12
RAV4 99/00 DRL relay D17 pin 2
Sierra 99/00 DRL relay D4 pin 2
Tacoma 2000 DRL relay D8 pin 2
Tundra 2000 DRL relay D7 pin 2
-disconnect battery- Then remove the wire with pin attached and tape to the harness. (consider just cut and tape the wire) -check operation- [except the 2000 MY-Avalon, additionally you need to ground the wire at the module end of the cut wire]
And here is the Headlamp relay part number.
1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif 1pixel.gif ACDELCO 1pixel.gif 1pixel.gif E1717C 1pixel.gif 1pixel.gif [RELAY-HEADLAMP] RELAY,HDLP OEM#89057700 ALL MAKES
1helpful
Cant find fuel pump relay on 2000 avalon
b/c u don 't have one u have c/opn relay ( circuit open relay ) that controls the fuel pump. which is located under hood fuse box a long the driver fender. good luck
1helpful
2000 Dodge Grand Caravan need to know where relay
the cooling fan relay is not in the fuse box.
it is a solid state relay bolted to the radiator core support just behind the bumper
Fan not kicking on for overheat
On the thermostat housing,the repair guide I see shows two one on top of the housing(controls the left fan) and one to the side(for the right fan)but this could also be caused by the cooling fan relay.
2helpful
Fan cooling problem. which and where is the relay or fuse for the cooling fan? I need a diagram showing me what the relays are for and what they operate.
I have the original owners manual, and it says that there is a fuse (No 16) and a relay (No 10) for the blower motor. I've same troubleshooting right now. If you wants send me a email to [email protected] to send you a scan imagen of the fuses diagrams.
Top TYC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a TYC Computer and Internet Expert? Answer questions, earn points and help others
