Hp laserjet pro 475dw. toner spill. Paper jam. found paper jammed in fuser. removed now only prints left half of page, right half is very poor to nothing. is it the user or something else.
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
LINK to part info
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
