Dryers don't need Shipping Bolts, only Washing Machines. The drum is supported at the back bearing and at the front by the drum rollers. A washing machine has a completely fluid, free moving drum to allow for uneven loading which is evened out during the spin.
if it is new you may need to remove the shipping rods that keep the drum secure for shipping look in the back there should be two of them if its not new I don;t know the answer
were the drum support brackets removed after purchase? you may need to open the front access panel and remove two brackets that support the drum during shipping. also at the rear are support screws that need to be removed
Not sure of particulars of this vehicle, but normally you must:
1. properly jack & support vehicle.
2. cannot have the emergency brake on, as this will prevent removal.
3. Remove tire.
4. Often, if this is the first time to remove, must remove some small retaining clips on the threads of the lugs. These are for factory shipping only, I usually destroy them in removal & discard.
5. Slide the drum off. Sometimes it requires the drum to be gently worked off if the brake shoes are in close contact with the drum.
The main thing you need to do, is to remove the toner bottle assembly, drum unit and developer unit. There is a small black stopper you'll see once you pull out the toner bottle unit. Remove the stopper and the tray holding the bottle will slide out of the machine. The drum unit has a thumb latch on top of the unit and all you have to do is open the right side door, release the lever and remove the drum unit. DO NOT TOUCH THE DRUM! The developer unit is below the drum unit. There is one screw holding a silver piece of metal which secures the unit in place. Loose the screw and fold it down to the left and then remove the developer unit. These steps will keep toner and developer from spilling out into the machine. Good luck.
The spacers are not important , And the rollers are not self lubricating , just add a couple drops of any weight of oil on the shafts before sliding the wheels on. You can add a few drops on the idler arm/belt tentioner as well while your in there.
Lube and clean dryer every year and it will last a long time.
Hope this helps.
Phil
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck. Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear. 2. Slide top back 2 inches to unlatch and remove. 3. Remove control panel with 2 screws at top, inside corners. 4. Carefully unplug 4 plugs from back of control panel. 5. Looking at inside at the top. Remove wiring bundle from 2 guides. 6. Unplug wire from dryer light. 7. Open dryer door and unscrew 2 screws behind door just below lint trap. 8. Remove 4 screws at top of front panel that holds the door. 9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect so I carefully rotated it an set it on top of the dryer. 10. Remove upper case bracket with 2 screws in front and 2 screws inside at top. 11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle. 12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove. 13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers. 14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove. 15. Almost done. Lift drum up at rear to free from rear rollers. Remove. 16. While your're there vacuume up dust and reverse procedure to install.
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum
Replace the imaging drum
Push the scanner-release button to open the scanner assembly.
Figure 1: Example of scanner release button location
Open the top cover.
Figure 2: Example of top cover being opened
Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
NOTE:
The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum.
Figure 3: Example of imaging drum rotation
Lift the imaging drum straight up to remove it from the device.
Figure 4: Example of imaging drum removal
Remove the new imaging drum from its packaging.
Place the imaging drum on a firm surface, and then pull the orange rings to remove the
shipping pins.
Figure 5: Example of shipping pin locations
Remove the orange shipping lock on each end of the imaging drum, and remove the two
orange shipping spacers.
Figure 6: Example of shipping lock and spacer locations
Remove the orange cover from the imaging drum.
Figure 7: Example of orange cover location
CAUTION:
Do not touch the surface of the roller or expose the roller to light for an extended period of
time. Doing so could cause print-quality issues.
Align the arrows on the side of the imaging drum with the arrows inside the printer.
Figure 8: Example of arrow location
Lower the imaging drum into the printer, and then press it firmly into place.
Figure 9: Example of imaging drum installation
