Since your phone is displaying "Not Charging" then there is a problem with your phone boss. Try changing your battery if not there is a temperature resistor inside the phone that has gone bad a good technician will do the job
Dear,
if your phone shows the sympol of "not charging" then one major power ic called UEM (universal energy manager ) will be the problem.
if ur phone is not shows that sympol and and not getting charging , then charging connector or a fuse nearby the connector may be the problem. this kind of problem can be solved easily by short circuiting the fuse and by cleaning the connector.
before checking these plz verify ur battery and charger by another
Your problem could be one of a few things...
1. your charger
2.your battery
3. the charging fuse....this would have to be dealt with by a service tech.This could be done by just shorting out the fuse with a piece of very thin wire and the phone will resume charging.90 out of a 100 times the fuse is the problem.
sam !
Mudabeer
your problem could be either that your fone has a problem with the charging pot or that the curent is not able to charge your fone
i can't charge the battery
