SOURCE: error 5C00 on Canon iP90
i took out both printer cartriges then put them back in. there was a window that asks if you replaced the cartriges; click yes then click on the black and color boxes indicating you replaced (re-inserted) both cartriges. for me the light stopped blinking (previously, it was blinking orange 4 times). next i tried to print but only yellow and black appeared. i then cleaned the head 2 times.
to clean:
-go to control panel
-click on printers
-click on printers and faxes
-find your printer, right click on it
-click properties
-find the maintenance tab
-click cleaning
(clean a couple of times if needed)
hopefully it works...
SOURCE: Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
SOURCE: I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Fixing this error is much easier as it looks. Unplug the printer
completely. Move the ink cartridge cradle gently to the left. Over to
the right at it's usual resting place you will see a small pad about 1cm
square. This pad and the area around should be covered with ink. Get a
microfibre cloth and press down on this pad - it's not fixed so should
come away with the cloth, otherwise use tweezers gently. Squeeze the pad
several times between your thumb and forefinger while inside the
microfibre cloth to remove ink build up. Then when not much ink comes
out on the cloth, clean the area in the printer around the pad so that
looks free from ink too. Then position the pad back in place, move the
cradle back into position, plug in and switch on - should work fine now.
But it's worth checking for any paper caught near the ink pad
SOURCE: Canon printer ip90V is showing Error 5C00
A 5c00 error relates to the sensor in the purge unit, which is where the carriage stops on the right hand side of the printer. You may find that the ink has built up in the purge unit and it will need to be washed out in warm water. The sensor in the purge unit will need to be removed before washing the unit. Problem is getting the purge unit out is quite tricky.
Rating the solution is highly appreciated.
