Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
A
Anonymous Posted on Apr 29, 2014
SONY RM-Y913 TV will not turn on green light flashes 6 times then turns red and flashes 6 more times
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Apr 26, 2008
SOURCE: sony trinitron kv-36fs76u
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
mortworker
  • Posted on Jun 15, 2008
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Anonymous
  • 61 Answers
  • Posted on Oct 15, 2008
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Anonymous
  • Posted on Feb 06, 2009
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Anonymous
  • 563 Answers
  • Posted on Aug 04, 2009
SOURCE: Sony trinitron WEGA won't turn on and standby
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Visit the link below so you can talk to Sony either on the phone or via online chat for your full range of options.
http://esupport.sony.com/US/perl/support-contacts.pl?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
tip
How to Program the Sony RM-Y913 Remote Control
Follow these steps to program the remote control.<br /> <ol> <li>Turn on the component to be programmed.</li> <li>On the remote control, press the <b>CODE SET</b> button.</li> <li>Press the <b>FUNCTION</b> button for the desired component.</li> <li>Using the number pad, enter the component's manufacturer code.</li><i><b>NOTE:</b> If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.</i><br /> <li>Press the <b>ENT</b> button.</li> <li>Point the remote control at the component.</li> <li>Press the component <b>POWER</b> button to verify operation.</li></ol>Follow this link in order to get your programming codes for your specific devices related to the Sony RM-Y913 Remote Control:<br /><br /><a href="http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMY913">http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMY913</a><br />
on Jun 21, 2011 • Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
10helpful
2answers
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
1helpful
Sony TV Model No. KP51WS500 flashes green & turns off
yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
4answers
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
1helpful
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
