Radio Communications Logo
Mini bluetooth speaker won't charge
Had speaker for about a month hardly used it but can't charge it. Doesn't work and the light just blinks blue
2 Related Answers
Anonymous
  • Posted on Jan 24, 2011
SOURCE: digipower bluetooth headset used with cell phone
I broke my headset and need to send for repair. Where would I send this product. I have the didgpower headset model #HFBLU-HI
Anonymous
  • 537 Answers
  • Posted on Nov 11, 2011
SOURCE: THE CHARGING LIGHT DOESN'T COME
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
Good luck from Headsets Direct!
What the green light by the charger area blinking green light indicating on my I candy speaker
See if we can get it working:
Charging Issue:
If the green light is blinking, it might be indicating that the battery is low and needs charging. Connect your speaker to a charger and let it charge for at least 3 hours. The light should turn green when fully charged.
Make sure you're using the correct charging cable and power source.
Auxiliary Mode:
A solid green light typically means the speaker is in AUX mode. This allows you to connect a non-Bluetooth device (like a laptop or MP3 player) to the speaker through the AUX port.
To switch back to Bluetooth mode, press the MODE button (usually represented by three overlapping circles). This should turn the light blue, indicating that the speaker is ready to pair with your Bluetooth device.
Check Connections:
Ensure that there are no loose connections or faulty cables. If you're using an auxiliary cable, make sure it's securely plugged into both the speaker and your audio source.
If you're using Bluetooth, try pairing the speaker with your device again.
Reset the Speaker:
Sometimes a simple reset can resolve issues. Turn off the speaker, disconnect it from any power source, and then turn it back on.
Volume and Sound Settings:
Adjust the volume on both your speaker and the connected device. Make sure the volume isn't too low or too high.
Check if the sound is muted or if any equalizer settings need adjustment.
Firmware Update:
Visit the manufacturer's website or check the user manual for any available firmware updates. Updating the speaker's firmware might address compatibility issues.
If none of these steps resolve the issue, consider reaching out to iCandy customer support for further assistance.
My blaster mini (new) wont charge
1.Check the LED light
Generally speaking, the LED light will start blinking when you connect the charging cord and charger to your Bluetooth speaker. Like the EasyAcc Mini 2 Portable Bluetooth Speaker features a 360 degree LED light which wraps around under the top metal and indicates the charging status. If the light is broken, probably the speaker is charged for real but the light says the opposite. If this is the case, try to turn it on after 1 hour's charging, if it works fine the LED light is broken for sure. It's not completely handy to use the defected Bluetooth speaker but at least there's no other system problems encountered.
2.Switch the charging cable and adapter
It has a great chance of applying broken cable or charger when the Bluetooth speaker not charging, therefore go to switch them to identify whether they are at fault or not. If so, directly replace them to qualified ones.
3.Clean charging port
Chances are that the charging port is choked with lint, dust and dirt. A can of compressed air can blow out the offending irritants and get your USB connection back to normal. If the charging port becomes loose, do not try to fix it by yourself if you don't get any experience with the tools like pliers or tweezers. Go to ask customer service or someone with solid skills for help.
4.Update/Reset software
The dead battery issue also occurs when the software is out of date, the manufacturers regularly release the updates or upgraded drivers to solve the corresponding problems. This happens on lots of rechargeable devices out there and there is usually a fix.
After all, if still says not charging, contact the after sale customer service and get support immediately or get it replaced under warrenty.
3answers
How do I know if my bose mini soundlink bluetooth speaker needs a battery?
[PDF]Owner's guide - Bose
worldwide.bose.com/.../soundlink_mini/.../owg_en_sou...
Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
Why does led flash blue then red constantly
Hello there,
From this download here
http://store.x-mini.com/upload/manuals/120416%20X-mini%20KAI%20Manual%20%28Eng%29.pdf
LED Battery Indicator
When charging:
Red - X-mini KAI Capsule Speaker is charging
Blue - X-mini KAI Capsule Speaker is fully charged
When in use:
Blue - X-mini KAI Capsule Speaker is turned on
Blue (dim) - X-mini KAI Capsule Speaker battery low
During playback through bluetooth, users will be alerted if
charging is required by a three-beep indication
If this is not right you will have to email them on [email protected]
or if is in Warranty, get it repaired by the Seller.
How stop the Bluetooth indicator always flashing on my Soundlink Mini?
Blinking blue light - Discoverable and ready to pair or reconnect with a device. See manual here: Bose SoundLink Mini Bluetooth Speaker Owner guide
6helpful
5answers
My bose soundlink mini won't charge or turn on worked fine for a while but now the red battery light is flashing fast every time I try to charge it it's been on the charger overnight and is still doin so...
I love my Bose Soundlink Mini 2. But, I faced a few issues sometimes.
Speaker not turning ONSpeaker not charging with the battery LED blinking.Speaker not getting connected to the bluetooth devices.
But all were fixed by reading through the Manual a bit. To help others, I actually made a video, to show some troubleshooting tips for the Bose Soundlink Mini 2. Checkout the video, if your speaker is not turning ON / not charging / bluetooth not getting connected:
This seems like a very common issue for the soundlink mini 2. This is due to a firmware bug. Gets foxed with a hard reset.Check the video for details and other trouble shooting tips.
Feb 22, 2014 • Cameras
Belkin mini mouse not working
try a different mouse if it works then your Belkin mini mouse
is defected.
1helpful
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
151helpful
7answers
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 • Cell Phones
Top Polaroid Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Polaroid Radio Communication Expert? Answer questions, earn points and help others
