KitchenAid KHMS2050SSS Microwave Oven Logo
E
Erik Posted on Apr 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My microwave seems to have a mind of its own it keeps wanting me to reset date and keeps beeping for no reason at random times
Dave
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 547 Answers
  • Posted on May 11, 2014
Dave
Expert
Level 2:
Prodigy:
Answers
547
Questions
Helped
232451
Points
885
Most likely it's an electronic failure of the main circuit board. Although extremely unlikely, I have seen an oven or two that have had these symptoms that were caused by an insect walking on the back of the circuit board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
  • Dave May 11, 2014
    Make sure, too, that the oven is plugged into a grounded outlet.
Time and date randomly resets on galaxy 3 tablet
Have you tried replacing the little round battery inside that holds memory when all other power is out. it is usually under one of the covers on the back where your memory is as.
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
1helpful
Randomly beeps for no reason at all. Can go 2 or 3 days then will start beeping. Day or night usually through the night.
hey i have the same problem. how log does it do it, how many beeps and how quicky. We have a danby also the 1.1 bought it about 3 years ago.
My microwave beeps for no reason even when not in
There is a reason. Try to reprogram the unit. Start w/menu: date, time simple stuff. This should take care of it.
2answers
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
6helpful
2answers
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
