Check on the autocad website, I presume you mean 16 bit?? they may have an archive. a;so, check websites such as oldversion.com oldapps.com. This might be difficult to locate but should not be impossible to find.
Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Autodesk not offering direct download of autocad 2010 products, they offer
product downloads for register users ofr trial versions.
But you can download autocad 2010 from torrents, but they not supports for
updates.
If you need more information about autocad products, go through this links:
Turn off your single document interface. Type OP and hit enter. Then select the system tab and check off the SDI (it should be towards the upper right of the dialogue box.
Here is an explanation of what NTVDM is:
The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model.
Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory.
Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
