SOURCE: Toshiba 6100
Unfortunately it is a fairly involved procedure, one of the more complex I?ve seen for a newer laptop. If you don?t have prior experience, tools and some nerve I?d suggest you take it to a shop. Some of the more challenging parts you are going to remove are the keyboard, the top half of the case, the wireless card and some of the wiring harness. -Remove the battery pack, any PCMCIA cards, the optical drive and the hard drive. -Open the laptop and carefully pry the keyboard holder (thin piece of plastic at the top of the keyboard. Toshiba has a special tool for this but in times past I have been able to successfully remove other Satellite Pro series keyboards with a plastic probe. Once that is off remove the two retention screws at the top of the keyboard, carefully disconnect the cable and remove the keyboard. -With the keyboard removed you will see the wireless card torx security screw at the top just to the left of center. Remove it, the cover plate and the card underneath. In order to remove the card you will also have to disconnect the white and black coax leads. When removing and reassembling note that these connectors are really small and fragile. -Flip the laptop over and remove all 15 screws. There are three different types so mark down where they go for reassembly later. -At the rear of the computer you will find 2x screws, one to the right of the VGA connector and the other in-between the serial and lpt1 port; remove them as well. -You will have to disconnect several leads and wire harnesses in order to lift off the top half of the case. -Once the case is removed the RTC battery is in the lower right hand corner. -Now all you have to do is reassemble the laptop and test. Good luck and don?t forget to rate this post.
SOURCE: ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
SOURCE: I have toshiba satellite pro L310.But i couldn't find
Here is the link for driver download for Windows XP
http://www.getpcmemory.com/drivers/download-toshiba-satellite-l310-notebook-windows-xp-drivers/
Download it.
That's it
SOURCE: toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
SOURCE: Toshiba Satellite P30 (new) Battery (and old) not charging
1. You will need to check the power adapter it may have lost it's ability to send a charge to the board.
2. Also the connector to the PC may be damaged and the solder joint at the mother board may have cracked or damaged.
3. Check also that you have the battery completely snapped in place.
4. check the contacts on the battery itself.
5. You PC may need service.
