Here you can see the steps page by page Samsung Corby Plus User Manual Page 24 Assembling And Preparing Your...
Samsung Corby Plus User Manual Page 25
enjoy!
SOURCE: for my samsung corby 3650 it says sim unavailable
try this security code, 00000000, but make sure you didn't change it before. if you typed it and the result is the same, consult the manual for phone, normally the codes are already there.,
if it doesn't give you a good result, try hard resetting your device. here's is the code *2767*3855#, but make sure to back up all your files through NPS and check if it will still ask for the 8 digits code when you insert your sim.
good luck..
SOURCE: my defult message memory
hi
go to the message settings of your mobile there will be some option that the default storage of message. kindly refer in that and change the memory to phone.. this will fix your problem.. if you still have any problem kindly contact your service and ask a solution for this problem..
thank you
SOURCE: When I insert another mobile
It may because of the Network Lock.,You need to Unlock the Mobile Phone from the Network Lock,You Can get the Unlock code at reliable cost at here
http://www.mobileunlocksolutions.com/samsung-s3650-corby/rs1wp9/ and Unlock the Phone....
SOURCE: My samsung corby gt-s3653 is
probably mobile tracker is on thus the problem
disable mobile tracker
SOURCE: how will i have my
To unlock the Mobile Phone call the service provider and get the master reset code and reset it....
