TV has no vertical pixels.
Contact the authorized service center for LG. There is nothing that you can do. Gopakumar Gopalan Google
Hi, Yes, as David says get a new TV. You will be better off with a new one. Price to repair is higher. Parts and Labor.
SOURCE: I have an LG 50PX5D-AB
Yes, those are called ghost lines and are caused by faulty buffer circuits - the circuits that directly command the pixels. The buffers are situated on the Driver boards - in your case, since the lines are vertical, on the Y-driver board. The fact that they have just appeared and the fault gets worse is a clear sign that the circuits from the Y-driver board are dying = you must replace the board as a whole. Here it is
http://www.shopjimmy.com/lg-6871qdh089a-ydrvbt.htm
SOURCE: Hello. My LG plasma 50pc3d has had red pixels
Pixels on a plasma TV are from the zustain boards. You might have one or both of them about to go out. Horizontal lines are most likelly one of your buffers or the screen itself might be going bad. You can buy the sustain boards by part number that you can get from the board itself from www.interliquidparts.com
SOURCE: black line lg tv
You have a bad panel. Will be cheaper to buy a new TV than to replace panel.
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
SOURCE: I have a green line running vertical on my 42 inches lg tv., How do I fix it?
Check its main power regulator board for any damaged electrolytic capacitors. Replace the suspected.
